A newbie here.  New to Chevy trucks.
Now own a, new to me, 2013 Chev Silverado 1500 WT 5.3L V8 Flex Fuel 4x4 Reg Cab Long Bed with 128K on the odometer.
The money pit I traded in (Ford F250 XLT Ext Cab Long Bed) had 146K miles on the odometer.  During my tenure of ownership it managed, barely, to get all off 6 mpg!
Glad I found this forum and glad to be here.
  • 3 weeks later...
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 839 Guests (See full list)
