hello fellow GM drivers. happy holidays.
I wanted to ask Has anybody had their radiator crack on their 19+ Sierra Silverados. Mine cracked on the driver side plastic side. It bulged outwards.  I did do a coolant drain and fill not to long ago. Perhaps I didn’t bleed the air enough and over pressure caused it to crack. Found this failure really strange. If anybody has any knowledge on how to remove It. I’d  appreciate it. I managed to get some some JB WELD. On the crack without removing it or sanding the plastic. But  it lasted 5 days because I didn’t prep it and sand the surface because I couldn’t reach in between the condenser enough. So the epoxy cracked and leaked ……
Already have a OEM unit being shipped. Just wondering if anybody had experiences removing this radiator on this body style. Because it looks over engineered like All vehicles nowadays. Have to remove a lot of plastics.
 It’s a 2019 Silverado CC Z71
5.3 8speed
OG owner.  keeping this bad boy  forever.
the uploaded image was found on Reddit from Some other truck 19+  owner. I have the same EXACT. Failure location. Strange.
Edited by 11bravoZ71
5.3 8speed
Sh***y plastic side tank on the radiator. I've seen a lot of them leak. Never done one on a T1. This is not unusual. They usually leak between the tank and radiator core.
Radiators (on anything) can fail, but it had nothing to do with air not bleed out.
Thanks for the replies fellas. Perhaps it was just bad luck.  Being plastic and all. A high quality all metal one for this body style would be nice. Once I get the new radiator and I remove this one and install I’ll update on the difficulty of the job.
 To those who might need to someday replace their radiator DIY on the 19+ GM trucks.  I Got the radiator installed. I watched  YouTube videos of the previous body style 14-18 trucks. And the process was very similar if not very close. A 3 hour job but in retrospect fairly easy. this video was spot on. Even though it’s the previous body style. It guided me through till done. I did have to remove skid plate to make the job easier. Just do it.
Attached I have my cracked crappy JB patch on the old radiator  LOL.
On the new radiator I lightly sanded the same area and applied JB WELD. As a preemptive move because it seems these radiators crack in this exact spot for some reason.
just replaced the radiator on my 19 with 104K Miles. Cracked in the exact same spot.  Its not a hard job, just a huge pain in the ass job unless you have tiny little hands.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   2 Members, 0 Anonymous, 1,164 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
