Over the past 2 weeks I’ve had an issue with my truck shaking. It doesn’t happen often and seems to be at complete random. I first noticed it while I was on the highway; I was was cruising at 60 mph and all of a sudden the engine temp was rising much higher than normal in the truck started shaking. While it was shaking, it didn’t wanna go above around 2200 RPM. So I pulled over and let the truck cool down a little bit and it seem to drive normal after. This problem didn’t occur again until a few days later I was driving back home and then all of a sudden the the truck didn’t want to get above around 2000 to 2200 RPM and the truck was shaking a lot. After that this is happened two more times and seems to be a complete random.
I’ve had some other things happen that I don’t know how related they may be, but here they are. About a week before I started noticing the shaking, I was driving down an icy back Road and my tires were spinning a lot and my engine temp rose above normal. After that happened, my check engine light came on and started flashing. I pulled over turn the truck off and back on, the engine light then went away and the engine temp dropped back down to normal. The other thing I noticed was about four days ago I got in my truck to start it, and when it was in just accessory mode, a prompt came on my dashboard that said “service stabilitrak”. Just as soon as it came on it went away and I haven’t seen it since.
The shaking feeling almost feels as if I was in a manual vehicle and I was a gear too high for my speed, then hit the gas.
I don’t have any warning lights or prompts on my dash right now. I am very lost as to what this may be, any help/insight would be greatly appreciated.
Thank You
Edited by Chad Krabbe
First, how long have you had the truck?, what is the milage?, does it have the factory 207 degree thermostat in it?
    Charly
    Charly
  • Who's Online   4 Members, 0 Anonymous, 2,763 Guests (See full list)
