I'm looking to level my 2020 Sierra 1500 Elevation.  Currently the front fender measures 3" less than the back from ground to fender.  By installing a 1.5" Leveling Kit, would there be any rake left?
i did an elevation with bilstein kit.....many ways to do it but yeah this is a HD forum
On 1/20/2024 at 1:00 PM, Another JR said:
3 minus 1.5 equals 1.5.
You probably needed a calculator for that one smart ass. I've read that leveling the front, lowers the rear slightly.  Looking for constructive criticism here so move along.
As others have said, you will have better luck in the 1/2 ton forum.  If you raise the front, you will slightly lower the rear bumper height as the pivot point is the rear axle/tire centerline.  (Just imagine if you hooked a crane to the front end and lifted the front of the truck, eventually the rear bumper would be almost touching the ground)
