Thinking about trying to replace the chrome grill / bumper on my 2021 Denali 3500 with the AT4 version. Anyone attempt this? Doable or major truck surgery?
Take a look at this:
Doesn't look super easy, but it also seems doable. I was trying to replace the AT4 badge on my 2024 AT4 grille and decided against it (the badge is really tucked in there), but if I was replacing the whole grille I'd definitely give it a shot myself.
Not sure how much more work the bumper is, but I'd imagine once you get all that trim off it's probably not too difficult.
Edited by BuckWallace
Wow @BuckWallace, thanks for sharing. I think the chances of me doing that without breaking one of those little clips isn't very good. All the same, I have a camera I need to replace (the front camera on my 2021 Denali is cracked) so I may have to at least lean the grill back. Was wondering how hard it would be to completely remove and swap it out.  This video helps alot!
I think the Video, is making it look harder than it is.  I have Chevy and Not the GMC but I suspect they set them up the same way.   I can drop my grille and bumper in about 30 minutes.
GMC guys correct me If I am wrong here.   On the chevy the left and right side trim under the head lights can be popped out from the center and left alone not detaching from the left and right wheel wells.  I am assuming this is the case with the GMC.
If this is case all you have to do is follow the grille detachment instructions and leave the lower trims attached but pull them back so you can get to the lower bolts on the grille.
As far as the bumper goes.  it is held on by 4 bolts on the top and to on the bottom.   just be sure to unplug the electrical first.
Good Luck, it is not as hard as it looks.
its really not that hard, the side moldings are the trickiest part ust take your time. i did it and the hood piece cause they wouldnt make a reg cab at4, so i made my own.20230722_131831.thumb.jpg.a1340c38e7d2ea0d9ad493acf03a867c.jpg
@Kjduvall that looks really sharp. Where did you get your parts? Straight from dealer, or did you find take-offs from an AT4? Wondering how much of an investment this is, and how hard it is to get the parts (mostly interested in grill and front bumper treatments).
For some reason I don't have the option to like or reply to posts...perhaps because I just joined?
yep dealership parts the grill was just under 800 and the nose piece was under 200 bucks, the bumper (stock chrome) was sand blasted and powdercoated black (my buddy owns a powdercoat place so it was free). but i dont recomend doing that, one small hit in a lowes parking lot and it chiped rather easily. when i do the bumper "skin" again im going to look for a non chrome bumper and have it painted with oem paint i think itll hold up better.
    ncleg
    ncleg
  • Who's Online   4 Members, 0 Anonymous, 693 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
