I think GM gives some wiggle room based on temp. I saw my recommended pressures were lower than the reprogrammed pressures my truck was set too in myGMC app.
On 1/29/2024 at 12:29 AM, Another JR said:
GM doesn’t actually give us recommendations for how much to reduce pressure at lower weights than the GAWRs, and I suspect they don’t want to take on the liability of providing that advice.
I don’t think GM necessarily “wants” the tire pressure to be higher in the rear when the rear axle weight is way below the front axle weight. I believe the OEM alert pressures for the TPMS are simply some fixed percentage below the maximum tire pressure recommended based on the axle weight rating and whatever handling factors went into setting the maximum pressures on the door jamb sticker. They only want to pay for a fixed alert level, and they want to give you a meaningful alert level for when you are maxed out (probably driven by DOT regulations).  Their 80 psi recommendation at 7200 RGAWR and the associated 63 psi alert level (and 70 psi and 55 alert level for the 2500) don’t account for the fact that, when empty, the rear axle weight is only about 3350 lbs.
Towing a medium or heavy trailer is a whole different set of concerns, and you want maximum lateral stiffness to avoid sway regardless of rear axle weight, so “good on ya” JT for running at the max rear pressure when towing.
I pump them up for the reasons you noted when towing.  I will say this though, the other day I had a piece of steel ruin one of my tires.  418 to replace it...ouch...lol...  And they scratched my wheel that I didn't notice until I got home.  I can't win for lose lately buddy.  I've got a dark cloud over me that won't go away.  Time for an exorcism I think...lol...
Edited by Jettech1
    Matt Parker
    Matt Parker
  • Who's Online   3 Members, 0 Anonymous, 870 Guests (See full list)
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
