The door locks began toggling and mirrors would fold in about three weeks ago while driving and after I was out of the vehicle. I have gone in the settings and turned off everything related to keyless remote use. I'm using the to unlock the driver's door and the lock/ unlock switch to unlock the other doors. I had a mechanic buddy attempt to clean the connection pins in the switch panel in the drivers door but that didn't have any effect. I read an earlier post that it may be the keyless remote sensor by the rear window defrost connection. Any updates or info as what it may be causing this , please.
Door Lock System Controls
The power door lock system can be controlled by any of the following:
  • A door lock switch LOCK or UNLOCK activation
  • A key cylinder switch unlock activation
  • A keyless entry transmitter activation
  • Pressing the driver door lock plunger flush with the door panel will lock all doors
Seems like one of those is activating the 'lock' command. Have to try to narrow it down.
Any codes (B codes specifically)? Typical code readers probably won't pull them.
Additional vehicle specifications?
I took it to a friend of mine who is a mechanic and he put a code reader on the port. What is baffling me/him is that it will not toggle when he's in the vehicle. Very odd.  I'm thinking that it may be in the switch harness in the drivers door. Still baffled with it.
I could be wrong but I thought the remote control module was up in the roof console. But that makes me wonder if you have a leak in the roof maybe? I know that sharkfin antenna is prone to leaking. I had mine replaced because of that and have read many other threads on it. If you have a slight leak, maybe there is water damage to the module and causing these malfunctions?
Another trick I discovered is you can fool the truck into thinking the door is closed by pushing the locking latch on the back side of door into the engaged position. Not sure why but these no longer use the pin switch to show door is closed, instead it's built into the latch. That helped me once before when I was working on drivers side fuse box but couldn't access it with door closed. I closed the latch and all power was off that happens with closed door.
Seems like the truck won't lock the drivers door if it thinks there is a key in it.
The driver door will not lock when trying to lock it if the door is open and the key fob is in the cab. It’s to prevent people from locking their keys in the truck.
I also read more on it and the remote sensor in the roof could have water damage. If that is the situation, would a new sensor have to be programmed to the truck and key fobs?
  • 10 months later...
My truck is doing the exact same thing.  I replaced the shark fin GPS antenna a couple years ago due to water damage. Is there a separate sensor up there?
Anyone fix the issue yet?
Thanks,
Tom C.
  • 3 months later...
Started having the same issue on my 2016 GMC Sierra SLT my mirrors would fold down and my doors would toggle lock while driving, after troubleshooting this annoying issue I decided to remove the battery from FOB and use my spare one what do you know problem solved, went and had another FOB made with my locksmith he said it’s a open circuit or a sticky button from years of use.. hope this helps someone else
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
