My latest project...
pacodiablo
Well, I finally got my little Zama carb finished and it is too cold to paint any model cars, so I got an old Quadrajet to work on. When I got it, the thing was caked in grime and dirt.
I removed all of the plastic and rubber peices and sprayed it down with some carb cleaner (not a full cleaning, just enough to see everything stamped on it).
That is all I am going to do with it for now. I still need to order the book on rebuilding these and the actual rebuild kit.
I rebuilt the QJ on my old 74 Vette. It was easy. I bought a book called (what else) 'The Rochester Quadrajet ' and a rebuild kit from (I think) summit.
QJs aren't as complex as you first think and I did mine in a couple of hours sitting on the front stoop with a 6 pack of fine ale in my cooler.
Here it is pretty much done, just need to get some linkage and a couple external parts taken care of....
It wasn't too hard to rebuild. A few parts, the primary metering rods especially, were kind of challenging, but over all it wasn't very hard to do.
I see you like working on carbs . ive got one i need to get rid of I was just going to throw it away .
You can have it if you want it . Ill even pay for it to be shipped
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
