I spend some time today dealing with a leaking sunroof on my 2020 LT Trail Boss Crew Cab, and I was unable to find any pictures or good descriptions (on GM Trucks or elsewhere) showing drain hole locations for entry or exit, so I figured I'd fix that.
Entry holes:
  • One on each corner of the sun roof.
  • To easily see (and access) the front holes, you need to remove the pop-up air deflector.
  • You can't really see the back holes, but you can see the hose coming out from the corner.  If you put water in the metal track, it will run back to the rear holes.
  • See arrows in attached photos.
Exit holes:
  • The front exit appears to be behind the wheel well lining on each side (I didn't actually remove it to verify); water will drip off the mud guards when draining.
  • The rear exit is on the back of the cab; if you look up between the bed and the cab you will see a black cylinder sticking out on each side.
  • 4 months later...
    • Correct.  2019-2021 model years are serviced by a different p/n.  19420611.  Recall 2021s use 19420611.   The recall engines 2022-2024 model years are serviced with 12740076.     The difference between 19420611 and 12740076 is GM changed injector size for 2022.  The injectors are smaller on 12740076 with smaller injector bores in the cylinder heads to match the smaller injectors.  So you can't install a 19420611 in a 2022-2024, and you can't install a 12740076 in a 2019-2021.     Both engines are the replacement engine p/ns that are in the L87 recall.  So both of these are the updated engines.     Here's a version of the L87 recall with the p/ns for all the parts needed.    RCRIT-25V274-7075.pdf   Note it shows 19420611 and 12740076 with an asterisk to a footnote "Use the VIN and the GM Electronic Parts Catalog (EPC) to determine which part to order if two or more part numbers are listed for the same part, as it may vary by vehicle options."
