Hey Everybody long time lurker 1st time posting. I currently have a 2015 5.3 Ecotec with an On3 turbo Set up. The truck is doing well but I wanted to get a motor on a stand to start building. Scored a great deal on what was supposed to be a 2018 L83 but it turned out to be a 2020 L84. I've done some research on my end but wanted to get reassurance from those with more knowledge.
When it comes to the Long blocks are these engines the same? I know the front accessories changed on the L84 but it seems I could bolt everything from my L83 onto the L84. They moved the dip stick and removed the vacuum pump. The heads seem to have the same part numbers, as do the HPFP, Injectors, intake manifold etc.
I did see the L84 has a different DOD delete kit and I have heard mixed reviews on if a l83 DOD deleted cam IE Texas speed stage 1 or GDP Cam would work on an L84. If the long blocks are the same I am not sure why one would have a different camshaft.
For the build I am not going crazy simply doing a DOD delete stage 1 cam with a 10-20% Fuel lobe increase and possibly a bottom end refresh pending what I find on the tear down.
Also some information on my current set up if needed. On3 Turbo set up with upgraded 76mm Oil less comp turbo, currently on 6psi 93 pump making 550whp. Built 900hp capable 6l80e with Billet Stock speed stall convertor.  I am content with the power and dont have any intention of pushing more boost if the stage 1 cam adds some power great but overall 550-600whp is plenty for me. From the research I've done it seems the stock bottom end can handle the power (Hopefully I don't jinx myself).
The only major change between the two is the DOD. but if you're deleting it then all should be good. The l84 is just the updated version of the l83.
The block is totally different because of the DFM, the L84 is a DFM engine and not a AFM engine like the L82.
So if the DFM delete kit is available, I would assume you need to use that over the standard AFM kit.
Edited by CamGTP
The entire valley is different on the L84.
L83 uses a VLOM in the valley plate, and has 8 oil passage bosses to feed to the VLOM.
GM Gen V Bare Block 5.3 Liter – Mast Motorsports
L84 (and L82) obviously the front accessories are changed (especially water pump) but the valley is different.  Each cylinder (4 for AFM or all 8 for DFM) have individual oil control solenoids and each has its own oil passages.  Green is the harness to power the solenoids, the red paint lines are on each of the solenoids.
So you'd have to use an L84 DFM delete on an L84.  I'd imagine the delete valley cover might be the same still?  Not sure though.
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
