DID A COMPLETE REAR BRAKE JOB, ROTORS ,CALIPERS, PADS BOTH R&L. TRUCK SEEMED FINE AT FIRST TEST DRIVE THEN PEDAL GOT SPONGY, REBLED BOTH SIDE, SOLID STREAM NO AIR. AS SON WAS PUMPING BRAKES I CAN HEAR AN NOISE LIKE A RUSHING SOUND COMING FROM ABOVE THE GAS TANK AREA. NO FLUID LOSS. ANY IDEAS?
Dumb question but you made sure to put the calipers on the correct side with the bleeders on top right?
YES
    • Follows the motif on the Sierra EV.  Satin finsh to the lower bumper area, painted above:   Elevation       Denali
    • Not exactly what I was hoping for, but I do like it. I wonder if they'll bring back Smokey Quartz Metallic? 🤔 https://gmauthority.com/blog/2026/06/here-is-the-all-new-2027-gmc-sierra-1500/
