I have a refreshed Denali. Wireless Carplay seems to be a hit-or-miss. I have BT/Wifi on my iPhone. The truck seems to connect automatically 8/10 times and for those 2 times that it doesn't I have to reboot the infotainment OR just unpair, and repair the iPhone. (This can take a few minutes and it's frustrating). Now, in my other refreshed Sierra (Elevation) I generally just plug in manually with a cable and never have those struggle bus issues.
Am I missing something here to why it seems to not see it sometimes, and other times it does? Both iPhone and the truck are on the latest versions. I have no problems going wired, but I'm just trying to understand how in the world this can work and not at the same time. It's frustrating when you're trying to get somewhere and it just doesn't projection automatically.
Anyone else experience these weird bugs/problems?
We are sorry to hear you are experiencing these concerns with your Wireless CarPlay and would like to investigate further. Please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We look forward to hearing from you.
  • 3 weeks later...
Multiple updates on infotainment system. ask for:
#22-NA-142: Radio Software Version W164 – Multiple Updates - (Nov 9, 2023)
THERE MAY BE EVEN MORE UPDATES
I’m 2 weeks in to a 2024 Sierra. CarPlay has been real buggy for me. I’ve done a hard reset on the infotainment system to fix it twice now.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
    • I have a 2026 base 1500 "WT" regular cab with basic Chevy "Infotainment 3" 7-inch screen/radio. How many speakers do I have If I want to upgrade? Is the audio amp separate from the radio/display unit]? [I listen to classical and it gets a bit raspy at slightly higher volumes. Don't need a sub etc.] Do I have two or 1 speakers in the doors? etc. Thanks Bill  San Jose
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
