Moved my truck last night and it started fine, went back outside to move it back into driveway 10 minutes later and wouldn't start. After messing with jumper cables for awhile it finally turned over. Drove it to autozone to have them test the battery and they said seemed like cell was bad and time to replace. Bought new battery, drove home and replaced and truck started up right away. Went out this morning and truck wouldn't start, just get a click. Battery seems fine when tested with volt meter, lights and everything work. Tried to jump it with two different sets of cables and a jump pack but no luck. All I get is a click.... Any thoughts? Starter maybe? I did get some message when I started it up last night about rolling the window down and then back up, which I thought was odd. The window was actually down so I just went up and then down...Thanks for any help, just trying to trouble shoot before towing somewhere.
I had that happen earlier this year on my 2016. My battery still had enough power as everything else worked, just wouldn't start it crank. I had mine towed to dealership where they diagnosed a bad starter and replaced it. It's worked fine ever since. Well fine except my transmission took a dump a month later...
Mine gave absolutely no warning. Always started whenever key was turned. This time turning the key and I got nothing. No crank, nothing. It ran fine up until coming out of ex-wife's house and trying to start to drive away. Luckily tow truck got there fairly quick.
Try taking a steel type rod & lightly tap the starter/solenoid a couple times the net time it does this. I it does start, yo have a sticking solenoid & will need to replace the starter.
How many miles on it?
Forgot to mention 2018 1500 Denali....
Edited by jdaddy33
sorry to hear about your transmission! I'm constantly worrying about that with these trucks. I had the major shudder issues at 20K miles. They did the fluid swap and has been fine since, but I've also had leaking from transfer case twice! Just dumped 4K into this truck in December (front struts, leaking seal in transfer case, front axle seal leaking, and engine oil coolant line seeping oil) and now they have already quoted me close to $900 if it's the starter. Should have bought the extended warranty!!!
I'm going to try tapping on the starter when I get back home today from work. Hoping to get lucky enough to get it started at least once so I can avoid the towing cost of getting to a repair shop.
Before I left I put a smart charger on the battery just in case.
It has 58,000 miles on it. If it is the starter what are the odds when I installed the new battery that it actually fired up?!?!?!? crazy! - thought I was good to go when that happened. Also makes me wonder if the battery I replaced was truly bad.... but it was almost 6 years old and the guy did test it at autozone.
Check the cables for corrosion. Use jumper cables to bypass them if necessary to test. Run a jumper cable from battery positive to starter terminal. Run a jumper cable from engine to battery ground.
It ended up being the starter. Sad to see a starter go bad that soon given how expensive these trucks are! Thanks everyone
    Chris80s
    Chris80s
  • Who's Online   4 Members, 0 Anonymous, 834 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
