Moved my truck last night and it started fine, went back outside to move it back into driveway 10 minutes later and wouldn't start. After messing with jumper cables for awhile it finally turned over. Drove it to autozone to have them test the battery and they said seemed like cell was bad and time to replace. Bought new battery, drove home and replaced and truck started up right away. Went out this morning and truck wouldn't start, just get a click. Battery seems fine when tested with volt meter, lights and everything work. Tried to jump it with two different sets of cables and a jump pack but no luck. All I get is a click.... Any thoughts? Starter maybe? I did get some message when I started it up last night about rolling the window down and then back up, which I thought was odd. The window was actually down so I just went up and then down...Thanks for any help, just trying to trouble shoot before towing somewhere.
I had that happen earlier this year on my 2016. My battery still had enough power as everything else worked, just wouldn't start it crank. I had mine towed to dealership where they diagnosed a bad starter and replaced it. It's worked fine ever since. Well fine except my transmission took a dump a month later...
Mine gave absolutely no warning. Always started whenever key was turned. This time turning the key and I got nothing. No crank, nothing. It ran fine up until coming out of ex-wife's house and trying to start to drive away. Luckily tow truck got there fairly quick.
Try taking a steel type rod & lightly tap the starter/solenoid a couple times the net time it does this. I it does start, yo have a sticking solenoid & will need to replace the starter.
How many miles on it?
Forgot to mention 2018 1500 Denali....
Edited by jdaddy33
sorry to hear about your transmission! I'm constantly worrying about that with these trucks. I had the major shudder issues at 20K miles. They did the fluid swap and has been fine since, but I've also had leaking from transfer case twice! Just dumped 4K into this truck in December (front struts, leaking seal in transfer case, front axle seal leaking, and engine oil coolant line seeping oil) and now they have already quoted me close to $900 if it's the starter. Should have bought the extended warranty!!!
I'm going to try tapping on the starter when I get back home today from work. Hoping to get lucky enough to get it started at least once so I can avoid the towing cost of getting to a repair shop.
Before I left I put a smart charger on the battery just in case.
It has 58,000 miles on it. If it is the starter what are the odds when I installed the new battery that it actually fired up?!?!?!? crazy! - thought I was good to go when that happened. Also makes me wonder if the battery I replaced was truly bad.... but it was almost 6 years old and the guy did test it at autozone.
Check the cables for corrosion. Use jumper cables to bypass them if necessary to test. Run a jumper cable from battery positive to starter terminal. Run a jumper cable from engine to battery ground.
It ended up being the starter. Sad to see a starter go bad that soon given how expensive these trucks are! Thanks everyone
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   0 Members, 0 Anonymous, 573 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
