After changing a leaky brake boost my brake lights stay on. When putting slight pressure on the pedal they turn off but when releasing the pedal they come back on. I do not see any adjustment on the connection rod from boost to pedal.
I changed the brake pedal position sensor and noticed the 3rd brake light was out so I changed that too but still have the same issue. I’am lost!
    • here is the high speed control wiring, i would also be checking  and cleaning ground connections high speed fan control.pdf
