I’ve read many posts about the plastic trim between the screen and HVAC controls (the one with the ugly wood trim piece on top) squeaking. Mine does as temperatures
change or as bumps move it slightly. I’ve had it off twice to try to fix it but it’s literally two pieces of plastic riveted together. I don’t see a way to fix it. I wrapped the HVAC control panel edges in electrical tape but that isn’t the problem. I can just push on that wood trim piece and hear the squeaks. I know others have this. Anyone found a fix?  I even looked for an aftermaket
piece like with carbon fiber or such and they do exist… however, are covers that you tape to the existing trim piece. That’s probably just something else that would squeak!
I also have the rattle in that area and now a new place that seems to be around the steering wheel area. I have tried changing the steering wheel positions to see if it will stop but it doesn't seem to help. IMO, this 2023 truck has been a rattle can from since I got it so disappointing. My 22 limited didn't have any of these issues.
We are sorry to see of this rattle concern you are experiencing in your vehicle and would like to take the time to investigate further for you. Please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We look forward to your email.
  • 8 months later...
Wow mine is not as bad as that video. That sounds pretty constant. Mine comes from impacts of the road. As the plastic pieces of the trim and and screen flex from impact, I get squeaks. I’m not sure there is a fix as you can just touch these parts and it squeaks.
Have you been in touch with your local GM dealership about these noises? If not, we would like to connect you to a dealership who can assist. If our assistance is of interest to you, please send an email to [email protected] with your VIN so we can take a look. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement:  https://www.gm.com/privacy-statement.
