Hey everyone, I recently picked up a used 2018 E-assist Sierra having no idea this was a “hybrid”. Now that I’m wanting to eliminate the v4 and start/stop stuff, all the message boards are recommending tunes (which I can’t seem to find who does this) or driving in D7. Can someone tell me what the heck is “D7” and how do I drive in it?
thanks for the help.
John
Edited by John_E_Ringo
What year is your truck?
D7 is 7th gear in the L range. Put it in L & u can shift up or down using the "+/-" lever. You must have an 8 speed.
You can disable both 4V & start/stop with a 'Range' device plugged into OBDII port. Google it.
It’s a 2018 and I’ve looked into the range device but have heard mixed reviews about it and harder shifting issues. Are these really concerns?
I have a '17 LTZ 5.3 w/six speed & install a Range 4 years ago when I bought it & haven't had any issues with it. In NC where emissions inspection is required, I have to remove it for about 50 miles to pass test emissions part.
If you don't want to spend the money and don't mind the check engine light being on you can just unplug the vacuum sensor on the brake booster line. That sensor is what tells the truck it's ok to go into v4 mode. No other issues will pop up if you do this. And it will be in v8 mode full time.
Edited by Homewrecker007
@homewreaker......didn't know that. However, I don't think it will stop his 'start/stop' function. I believe u can buy the Range to do both.
That I have no experience with. My trucks didn't come with that function.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
    • We understand your frustrations with being unable to open your Sierra’s top inner tailgate, @smitty81503. Your concerns are frustrating, and we would like the opportunity to explore the best path of assistance to pursue their resolutions. There are many different factors that could be the root cause of vehicle concerns, and we handle each one on a case-by-case basis. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
