What would cause a number 2 connecting rod to break in two separate engines in a 99 Chevy Silverado 5.3, LS engine? car wouldn't start in parking lot, was wiring in column. On the way home, started smoking out white smoke on passenger side exhaust that smelled like fuel. Was running the engine, trying to find the problem and the number two connecting rod shot through the oil pan. Put in another engine and it broke the number two rod again. Any ideas? I'm out of engines and ideas, lol.
Same or different injectors?
#1 cause, lack of lubrication. These engines are notorious for oiling issues, either with age, or self-inflicted (by the last person to work on it).
#2, Power adders ... AKA, too much boost (from supercharger or turbo[s] ) one too many times. They'll spit con rods every time on a stock engine.
#3 hydrolock. Sucking in water driving through water, or a massive head gasket failure allowing coolant and oil in the combustion chamber (not common). Usually bends, but can break them in extreme cases.
Complete and total injector failure, new or not! Either it got damaged during installation or they're the worst quality counterfeit or chinese parts available.
That would most certainly bend or break a connecting rod, destroy bearings by diluting oil, fry catalytic converters to a cinder, etc..
They were, I will tell my husband. Ty very much.
20 hours ago, Gina Taylor said:
Anyone know why fuel would come out of the passenger side exhaust?
Stuck open injector. May also cause hydra lock
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 660 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
