2020 Sierra 1500 Denali 6.2
About a week ago I had a strange bunch of error issues, no power steering, running boards going backwards when the door was opened etc. Never tried other features like active cruise control or lane assist.
I thought it was an old battery issue, but found out on this forum that it could be a bad grounding strap -that was what the problem was and it seemed to fix all of the problems. It was the braided one on ps from the frame to the firewall.
Since many on here and on the Corvette forum says to change the battery in 3-5 years to keep from having problems, I decided to change the battery.
Replaced with the correct ac/ delco battery and everything still seemed fine.
But, I just took it on the first highway trip and I have two problems:
1 adaptive cruise control temporarily unavailable and when I try regular cruise I get nothing.
2 lane assist is not working and when I use the switch it does nothing -no message regarding on or off.
I didn’t time how long the cables were off, but I’m thinking that it wasn’t long enough to do a reset ?
Maybe the voltage drops that happened before I replaced the grounding strap, had also goofed up acc and lane assist?
Should I take off the battery ground cable for 15 minutes to see if that resets it or is there something else that I should try?
Pull the forward collision camera fuse for 15 minutes and put it back in.  See what happens after that.  Fuse F18 in the passenger side dash fuse box.
Tried that and no luck. Thanks for the recommendation!
Anything else I can try or do I have to give in and go to the dealer 😳
I also tried taking off the negative battery cable, with the headlight switch on, for over 20 minutes and no change.
Its probably gonna need the camera then if it won't reset.
On 8/11/2024 at 2:02 PM, Glava2876 said:
Thanks- guess I go to the dealer
Our team regrets to hear you are facing these concerns with your vehicle and would like to learn more. When you have a moment, please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We will watch for your email.
Thanks, I did send it just a little bit ago!
Ok, brought it to the dealer and had sensor/ module communication errors. They did a system update and all set!
Total cost just over $200.00 -same day service.
  • 9 months later...
2020 Silverado 2500HD, after replacing batteries, lane departure "unavailable", collision avoidance not working.  Dealer relearned camera system but still not working and they can't find any service bulletins related. Looking for ideas.
Edited by Dave Bittel
    • No engine digit "E" for 2019-2026.  Stop reading slop online     All 2026 V8s have functioning DFM.  Hardware and software.  5.3 and 6.2.  The L84 5.3 has "D" as the 8th digit of the VIN, the L87 6.2 has "L" as the 8th digit of the VIN.       If you want a factory DFM disabled 2019-2026, you'd have to find a used 2021 or 2022 chip shortage truck.  The vehicle build data will have a specific RPO code indicating its a factory disabled truck.  RPO code YK9 and only with the L84 5.3 engine.  These still have the hardware installed but are NOT functioning due to the COVID chip shortages that were ongoing.
    • My post above is the direct reason for my outsized interest in keeping what I have for as long as possible. My memory isn't as short as some.
    • I don't think so. 😏 Cars? Our experience will diverge there as well. I was buying cars with 200K (1970's) when I started and quite a few were pretty solid cars. (My early stuff was 1964 to 1968)  Some stinkers but not the dismal picture painted above. Now that said, yes, a dealer wouldn't talk to you if your car had more than 60K on the clock and lot cars were 60K or less except the back row where 100-120K was the auction bought for dirt for us poor losers. Kids in my county were not allowed to wear long pants if they couldn't rebuild and repair every part of that beast.    I will agree that many parts are now better. Alternators and charging systems are an envy. But I replaced few water pumps or power steering pumps then. Rebuilt carburetors but replaced few. Mufflers are another place of OEM improvement. Stainless? We didn't have no stink'n stainless.    As long as humans are in charge of governance this $$$$ situation will not improve.    The purchasing power of a dollar in 1955 is significantly higher than in 2025, meaning that a dollar could buy more goods and services in 1955 compared to 2025 due to inflation over the years. For example, what you could buy for $1 in 1955 would require approximately $10.50 in 2025.  Calculator.net inflationtool.com   Comparison of Purchasing Power: 1955 vs 2025 The purchasing power of a dollar has changed significantly from 1955 to 2025 due to inflation. Below is a breakdown of how much more money is needed in 2025 to match the buying power of a dollar in 1955. Purchasing Power Overview Year Equivalent Value of $1 in 1955 1955 $1.00 2025 $10.50 Key Points Inflation Impact: The value of money decreases over time due to inflation, meaning that the same amount of money buys fewer goods and services in the future. Example of Inflation: What could be purchased for $1 in 1955 would require approximately $10.50 in 2025. This illustrates how inflation has eroded the purchasing power of the dollar over the decades. Understanding these changes in purchasing power is crucial for financial planning and assessing economic conditions over time.  Wikipedia Calculator.net
    • The thermometer has been in my wife's 2008 envoy, my sons 2016 chevy, my friends 2020 1500 silverado all showing cooler readings. It's not the guage.
    • Have a question concerning trim levels. Ive not bought a new vehicle since 2006, and I have decided on a 2500 gmc pro or silverado custom. For anyone that has one of these 2 trim levels have you regretted not stepping up to the LT or SLE. I look at things as the more electronics the more problems to arise. I love the look of the old school gauges on the dash as well. Looking forward to hearing your thoughts.
