Has anyone found a way to scroll through the full list of music when using a USB drive? If you use the USB, you probably know that scrolling is limited to a very short list while driving. This is probably done for our "safety".
You know what that forces me to do? Use my phone instead of the USB and scroll through that. Given how small the phone screen is, it would be much, much safer to be able to scroll on the larger screen. Basically, their short-sighted decision to limit scrolling while driving makes driving less safe. (Let's not forget, SiriusXM scrolling is not limited)
The other thing is switching from USB to SiriusXM (or any other audio source). If I'm in listening to an album on USB, I have to keep pressing the Back arrow until I eventually get to the home of the audio source. Only then can I switch from USB to another audio source. Again, that back pressing while driving is potentially not safe. (If there is a way to get around all the Back pressing, it's not obvious enough)
I've been a software engineer for a long time and developed quite a few interfaces. If one of my engineers came to me with that interface I would send him back. This shouldn't be a big deal, it really is a pretty trivial thing. Other manufactures like Ram and Jeep get it right. I've seen such bad design or let's call it lack of attention to detail from:
1. people who don't give a f#$%. If employees don't give a f#$%, that attitude more often than not trickles down from upper management
2. beginners (who shouldn't be given the responsibility for such a task)
3. offshore outsourcing (who shouldn't have the final say in such a task)
4. all of the above
Ok, I'm done venting... I realize that most people probably don't even use USB audio.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
