I bought the GL7 Upfitter switch kit with the knee bolster.  Doesn't look like the bolster will fit a 2024 HD.    Anyone want to buy the knee bolster with the switch cut out (LOL)?  Looks like up to '23 for this panel.  Seriously though, if anyone needs it I'll sell it.....
Anyone done this MOD using the panel that goes under the center stack in the console trim?  Looking for the part number(s) for the trim pieces?  I'm not really too shot in the butt about cutting my existing trim panel...
