2011 Silverado LT 5.3L 136K
Power Locks and Factory remote start.
the cable that goes from the interior door handle to the lock broke.  the head broke off at the handle.
i think I may have ordered the right part to replace it.  I didn't realize there were different sized cables for manual locks, power locks, and what does remove start have to do with anything.
anyway, this is the cable i bought.  its 25.8" long.
Amazon.com: Sousery Inside Door Handle Latch Release Cable Compatible with 2007-2014 Chevy Tahoe Sierra Yukon Silverado Escalade,25.8" Door Latch Cable Replace 924-481, 22862028 : Automotive
can anyone confirm I got the right one?  I didn't take my old one off yet and I wont until I get the replacement.  and I cannot seem to find any tutorials on how to replace (i only find videos for manual locks)
any help would be greatly appreciated.  thanks
See if this video helps.  It says its for '07-13.
There are also videos on taking the panel off that may help you.  Hope this helps.  It looks like something I would not want to tackle myself.  If you have a body shop man you know they could have that done in 30 mins.
thanks for the videos - I have taken the door panel off many a time.  I had a broken handle last year.  now the cable.  the first video showed will help a lot.  I think I ordered the right part (cable).
my cable comes in Tuesday, so I will report back at that time.
so, the cable worked.  was exact fit.  and thanks to the first video posted by Jworks, it took me 30 minutes.  Power Lock, remote start, everything works and fits well.  the part I listed was $12, the Dorman version (924-481) is $50 - not sure why.  but problem solved.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
