Gents. How can I sell if my 23 trailboss has adaptive cruise control? I have the gap adjustment button and the manual talks about adaptive cruise but when I try and follow the manual to turn it on, it doesn't do anything. Any help?
 press and hold the cruise button on the steering wheel. That's the left button. If you have adaptive cruise it will show a car symbol above the cruise symbol at the top of the DIC.
I tried numerous times on our last road trip and nothing pops up. I'm guessing my truck doesn't have it.
That's for the gap distance for forward collision.
Like Phantom 4D mentioned, if you press and hold the cruise or cruise cancel button it will cycle between standard and adaptive, if you have it on there.
Not available on 2023 Custom Trail Boss
RPO code is KSG
On 2023 LT Trail Boss it requires RPO code PCM  - Convenience Package II
Check the QR code on the doorpost, it should show if it is installed.
RPO code is KSG
Ill look. Thanks
RPO code is KSG
,2023,CK10743,10,22,01,BWWPQQ, AXK AY0 A2X A50 A7E CJ2 C5Z DLF D31 EF7 E63 FE9 FHX F48 GTL GU5 G80 H0U IOK J23 J61 KW5 LZ0 MAH MQC MSL NTB N10 N57 RD1 RM7 R3O UDV UQF U2K V8D WMX XCQ X88 Z7X Z82 2LT 4AA 6TT 7TT 8AZ 9AZ,661G,,,,
It's an lt but not installed.
