I have a new 2025 Silverado 2500HD with the power up and down feature that I slightly damaged on the top and tweaked it. I may have to locate a new take-off. Tailgate.
what years fit?
anyone know of a place that does take offs? I already looked locally at upfitter shops and Facebook. No dice….
prefer a Black LT tailgate if anyone knows of one! With bedliner sprayed. It’s a long shot…….
Is that a new feature for 2025? My 2024 Denali doesn't have it.
57 minutes ago, Crazy Canuck said:
The multipro tailgates don't get the auto up.
That makes sense.
15 minutes ago, goodtux said:
I was having the exact same issue and just replaced both my main batteries on my 2020 GMC 2500HD Denali and it fixed it.
You're a spammer. Embedding a spam link hidden in the op's post? You're a low life.
    lanaderay
    lanaderay
  • Who's Online   4 Members, 0 Anonymous, 1,532 Guests (See full list)
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
