Can’t find a tool to remove the nut on the banjo housing. According to my dealer it’s not available to the consumer so he says I have to bring it to the dealer to replace the rotors.  I’ve never heard of such a thing!  Any suggestions?
Thanks.
Thanks.
DT-52989 which is backordered but there's an aftermarket one - DT-52989 ProShear Nut Socket Tool Alternative
EDIT - As gemarsh added below, Amazon has some other alternates.
Edited by newdude
Hope you ordered new nuts as they are one time use.
Is that the same nut socket as the 11.5” 2500s? If so I’ll save the reference for when my time comes.
What don't I understand?
https://www.amazon.com/Powerbuilt-648473-Spindle-Socket-Outer/dp/B0015UV6LQ#aw-udpv3-customer-reviews_feature_div
I know the rear seal is a one time use according to the service manual. Didn't know the nut was.
Edited.  I was thinking of the single rear wheel trucks where they changed the design of the nut.  Disregard my "one time use" note that I have now removed from my original reply.
Edited by newdude
1 hour ago, mrjulian416 said:
You have to remove the hub nut to remove the rotor?  Is that a 3500 DRW thing?
2500 rotor removal
Dually thing.  On these 2020-up the hub is bolted to the rotor.  You have to remove the hub and rotor assembly to then access the bolts to separate the rotor from the hub.  The prior generations so 01-19 trucks the wheel studs where what held the rotor to the hub so you had to pull the hub and then drive the studs out to separate the hub and rotor, replace the rotor and then flip it over and drive the studs back in to put it all back together.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   5 Members, 0 Anonymous, 1,931 Guests (See full list)
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
