I am thinking about buying a new 2025 Silverado pickup. So lately "Here in Michigan" I have been looking at what others have, and noticed that quite a few have upper rear fender rust through. The lower parts of the fender ahead and after the wheel look fine with no rust. Looking at the rest of the truck, lower doors, front fenders and lower tailgate show no rust at all. Not good at determining what years these truck are, but they do not seem to be that old. Does anyone have any info as to how old these truck get when you start seeing rust?
Mine is only a 2023 but so far only has one very tiny spot of surface rust on the passenger inner fender well. I sprayed cavity wax inside the area between the box and the fender by pulling the oval plastic plugs inside the bed and inserting the spray wand for my 3M cavity wax in there and moving it back and forth to evenly spray the cavity.
I also take my truck to rustkote for being sprayed. They spray the underside, bottoms of the doors, inside the rockers, in the bottom of the tailgate. So far there is no sign of surface rust but I also take the fiber wheel well liners out in the spring and thoroughly wash and wax inside the wheel wells then put the wheel well liners back on the truck. I also every 2-3 weeks will wash my rims out with a wheel woolie and the left over spray soap I spray the bottom lip of the bedside fenders and use a small soft bristle brush to clean out the dirt and salt.
I'm hoping to make my truck last longer than my old 2014 that started to rot out in the rocker on the passenger side towards the rear door and had rust bubbling on the fenders of the bedside. That truck wasn't owned by me for 3 years since it was a lease before I bought it, my 2023 has been mine since a few months after production since it was a loaner used in the summer from the dealership before I bought it. I hope that because of this and my rigorous maintenance it might last me longer before the wonderful new york state saltbelt kills it.
anything steel will all rust if you don't do preventative maintenance like oil coatings.    if I'm not mistaken the doors hood and tailgate are aluminum so no rust, but bedsides, rockers, cab corners, and front fenders are still steel so you have to spray the inners or watch them rot.  Take a magnet to your truck, if it sticks it will rust.
I really do believe the GMC trucks that have the plastic around the fenders is the key to not rusting.  I had a 2015 Sierra for over 9 years no undercoat or oil spay. No rust at all above rear tires above bed. I see 14 and 15 silverados  with rust all over right there.  I just bought a 2024 silverado I guess I'll see in time. And I live where they put salt down all winter on the road.
Common rust problems?  Western NY, I haven't seen any of these 19+up trucks with body rust issues yet.  The frames still do that crap the last two generations did where the wax starts to get blasted off and it starts to rust.  Seen some rough ones too.
Can't say I've seen any with body issues though.  14-19 previous generation?  Big time.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
