So, my first seeing of 86 octane that is also 10% ethanol.
Im halfway through a month stay in New Mexico, about 60 miles south of Roswell.
     The choices hear are as mentioned the 86, then jumps to 88 and up 2 more choices, seems all are 10% ethanol or so the pump says. The cost jumps .70 cents a gallon from the 86 to the 88.
      I looked up why an 86 and its seems because of elevation, its normalish. I was towing the 5ver/home when first encountering the lower gas, so put in the 88.
     I just did a 350 mile trip, just pickup, to check out a motorcycle, and put in the 86, driving empty to check out the bike.
    It ran like normal on it like it normally does on 87, same fuel mileage or close enough.
    When i leave at the end of the month, ill fill with the 88 as well as the in bed transfer tank, for towing, just incase, as ill be going back to sea level areas.
I tow in the West a fair bit.  If I know I'm going to be above 5000 feet for an entire tank, I'll run 85 or 86 Octane, then put in 88 or 89 in the next tank when I know I'm going down hill.  Never an issue doing so even towing heavy in the hills.
On 12/19/2024 at 2:44 PM, mrjulian416 said:
You would never notice the difference between the 86 and the 'normal' 87.
86 and 88 seems to be odd when 87 seems to be the norm across the continent. I didn't notice when I was in the Canadian Rockies last year.
I am surrounded by it in New Mexico from I-10 to mid state, havent been farther up yet. First time i have seen said 86 with 10%  ethanol let alone 86.  I can now say i am missing 1.5mpg vs the 87 with ethanol. Thats taking into account winter blend. At 22,000 miles on mine now, i have a good feel for its fuel usage., per terrain and wind, summer vs winter.
Again, when i leave/tow  650 miles to the next place, at the end of the month, ill be doing the 88 till i get to 87 areas.
    ShowMeShooter1332
    ShowMeShooter1332
  • Who's Online   1 Member, 0 Anonymous, 6,049 Guests (See full list)
    • I was around and remember that era very well, so I'm calling b/s on that statement. If they were that bad no police department or taxi company would've bought a single one ... but they were used in both services (and fire) for DECADES. They were bulletproof and proven. Even the early 21st century ones weren't too bad! The early models were legendary.   Mine is proof, but people like atlas are blinded by agenda and refuse to believe facts right before their very eyes.   Even decades after they were built, a new generation started driving them, posting all their builds and shenanigans on Grandmarq.net and Crownvic.net. The failures would show up then, since they all were deep past 100k-150k miles by that point, and younger drivers tend to be a little aggressive, especially with vehicles than can lay a one-tire fire for as long as you hold your foot in it. They've more than proven themselves over the decades.   The only thing that'll really take them out is road salt. The bodies and sheet metal were garbage. A victim of the cheapout FoMoCo and GM have been partaking in before then, and since.   Today it's the stuff that counts - the undercarriage that rots away first!    GMs Caprice was no slouch either. Reliable as a stone ax - the opposite of what they build now.
    • Let me know how your vehicles do in 10 years. You don't know ******, kid. 😂    There's a reason that Panther platform was used as police, fire, and taxi service for DECADES ... long before you were born, apparently.
    • If your connector also has a big lever to get the connector on and off, you don't want to force the lever either way, as it becomes a bigger problem if you bust the lever or the mechanism it works.
    • It's just useful to disconnect the battery to prevent odd shorting out when unplugging/plugging stuff together.  I also  touch the two cable ends together (after disonnecting) to drain the small amount of stored battery energy in various modules.   I believe the main system where you need to be more concerned with, so you need to do the above and then wait some time, iss when you are working on the air bag system, to prevent inadvertent firing of the air bags.   The in-cab switches are just that, plain switches, it's generally not a problem to swap them in/out.  For my '12, I'll get an error message on the dash if I power up the truck w them unplugged, but that's it (power up= turn the ignition on).   The ITBC located above the spare tire is a computer that manages the trailer brake system.  That is probably more important to have the battery disconnected.  It does have to be programmed to the truck, either before or after it's installed, for it to work.  For my '12, I had a very hard time reinstalling the main connector to it (IDK if yours is the same or not), it turned out the silicon seal was jamming up, preventing it from going on all the way.  I finally got it fully installed by lubing the seal with a bit of dielectric grease, then it slid on and latched in place easily.
    • JR ! I just got the truck back from the Dealership today . The technician did a cold remote start on the truck this morning and it made the noise . It was determined that it was a starter issue and replaced it under warranty . Of course   it did not make the sound after a new starter was put in because the truck was not cold . We will we see what happens tomorrow morning when I start the truck cold  . Keep tuned !   Oh I found a video on YouTube of a cold start and it did the same thing your truck and mine do , I will see if I can find it and post it up
