As the title says I have a 2011 sierra 1500 with the heavy duty cooling(K5L) package and the Z82 trailering package.  From what I see online the K5L trucks have larger oil cooler lines than a standard truck.  A couple guys that did write ups on repairing the lines had 3/8" the same as the trans cooler lines.  The oil cooler lines on my truck are visibly larger in diameter than the trans cooler lines.  I just repaired one of the trans lines today by cutting the factory crimp connectors off and replacing them rubber hose with new hose and pinch clamped it to the steel lines.  The 3/8" I.D. hose was loose fitting on the factory barbed fittings so I'm hoping the 3/8 hose will fit but maybe a little snug on the oil cooler lines.  It's most likely a long shot but figured I'd ask if anyone has done this before and knows if 3/8 line fits or I need to buy the next size up?
You will need 1/2" hose, Probably will have to use hydraulic hose or a barrier hose. I hope you used power steering hose on the trans lines, Fuel line will swell up and burst. Usually the hoses are ok, just remove the crimps and double clamp the ends
If the fittings used are any indication, 3/8 for the transmission oil cooler lines and 5/8 for the engine oil cooler lines.
2007-2013 1500s there's only one set of engine oil cooler lines listed for these with a V8.  There isn't two different sizes either.  84828848 is the engine oil cooler lines, bigger than 3/8", probably closer to 5/8".
Trucks without heavy cooling K5L don't have engine oil cooler lines RPO code KC4, just transmission cooling but without the aux cooler.
K5L adds the transmission aux cooler and the third line to complete that circuit, and adds the KC4 engine oil cooler lines.
Edited by newdude
  • 1 month later...
Thanks for the info, it's been awhile since I've been on the forums.  I got the job done and 3/8" ID hose fit on both the oil cooler lines and the trans cooler lines.  The trans lines were a bit smaller but it still worked.  The 3/8" line was a perfect fit for the oil lines.  I used pinch clamps like the type used for PEX tubing in plumbing so they pinched the hose perfectly.  Been about 2 months now and no more leaks!
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
