Hello everyone, I have a 24 Sierra Elevation X31 with a 1.5 level. I'm considering K03 tires but can't decide between 275/65/20 and 285/60/20. I prefer the look of the 275/65, but will it require any trimming? I want to avoid cutting anything. Any advice would be appreciated. Thanks!
Search around, or check out custom offsets website and put in the truck/wheel/tire combo and they’ll have a description on what was needed to fit
275/65 is a 35" tire.  285/60 is 33.5.  Roughly.   I had a 2" spacer in front and fit 305/55r20 on the front with now rub. Those are 33.25 but a lot wider.  I think the  285s would work okay.  With 2" I think 275/65 would work but it might look kinda stuffed.  FWIW, 275/65 is a much more common size and a lot cheaper.
Im currently running the new Terra Grappler G3 in 275/65r20 with a 3.5 lift.
