Oil Bolt Size
I have an '01 z-71 with the 5.3 motor. I messed up the head on my oil bolt and want to go to the auto store and get a new one. Any idea what size thread it is? I didn't strip the threads just the head of the bolt. I couldn't find the info. in my owner's manual.
Thanks
I dont know what thread size it is...but I was able to get a drain plug (not oil bolt...you say that and they'll start lookin at you funny) for my truck from NAPA. All I had to do was tell them make, model, year, and engine.
Not quite sure how you managed to mess up the head of the plug. What size socket are you using? Keep in mind that it is metric.
:thumbs:
Ya its 15mm but the stupid thing says 1/2 on the bolt. Now who thought that up?
yep ...15mm is right....I think the 1/2 in on there because the theads are 1/2inch 14.
I think ??
to be 100% sure you should call the dealership and have them look up your vin# they will be the only way to be 100% sure.
:sigh::P
What??
No need to do that, all the engines use the same plug. Just go to any parts store, tell them your make & model and they can hook you up.
  • 2 years later...
Go to the dealer and get a new one. If you get a universal oil drain plug, even if it fits, it may not be exactly the same and the sealing gasket may not seal properly. It is not worth trying to save a dollar in this case.
checked again today, 15mm won't work... I took pics to help with my delima w00t
Far away you can see oil filter and then drain to the right
close up of the same one above
This one is with that cap screwed off. alought I'm not sure what it does...
Am I looking in the wrong place? I've changed oil from here before and haven't had any issues..
Thanks for any help
