I have a 2024 chevy 2500 HD LT. My mirrors are mirrors only. If I buy OEM with the cameras, blind spot monitor and power fold, will they plug and play? is there anything I would need to make this upgrade work.
No.  There is A LOT to the camera system.
Are you just really trying to get towing mirrors?  Or are you really set on trying to gain the added features?
I have the tow mirrors that came with the truck but 0 features. Was looking at getting, heated, blind spot monitor, and side camera ones
You won't be able to do it at least from GM.  Blind spot monitoring can't be added to a truck, must be factory ordered.  Modules and wiring will all be missing from yours and can't be added after the fact.
The standard LT towing mirror has heat and turn signals, power upper glass, manual fold and extend.  Option code DBG.  So you already have heat.
I've seen a couple people do the 360 cameras on older like 2020, its very $$$$ and you need ALL of the cameras for it to function.
There is an option though via the aftermarket for doing camera mirrors.  Echomaster sells their Intellihaul kit.
Link HERE - Intellihaul 3.0 Trailering Camera for Silverado and Sierra Trucks
[b]The standard LT towing mirror has heat and turn signals, power upper glass, manual fold and extend.  Option code DBG.[/b]So you already have heat.
I'll take your word on the RPO code, but your description (plus the cornering camera when towing) matches what I have on my 2024 LT. I'm curious about the 'basic' tow mirrors that the OP had. I kind of thought mine were the base tow mirror compared to what the LTZ tow mirrors have, the added power folding & telescoping. My nephew was showing me those features the other day on my brother's truck.
You have DWI mirrors with the PQB safety package then.  PQB has the 360 surround view and blind spot.
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
