Hey everyone,
I am new to the community and I just purchased my very first Silverado. 2014, very clean. I am pretty happy with it.
I was always planning on putting a leveling kit on as soon as I bought a truck, but I am wondering if this truck has already been leveled. The top of the wheel well is currently sitting at 37.75 inches (front) and 38.25” (rear). But I cannot see any hardware that would indicate that it has.
it is sitting on 22’s so maybe it’s just the bigger rims?  I was expecting the top of the wheel wells to come in more at like 36.5”
It was bought from a small dealer and I didn’t even ask.
Anyone do a 2inch level and can report hight at the top of the wheel well?
Thanks!
Just now, Aturek said:
Hey everyone,
Thanks!
Sounds like it has one done already being you are only a 1/2" lower up front.
Got any pictures of the front suspension?  How about one of the truck from the side on flat ground?
Ah, it's got Bilstein (most likely 5100's) struts. There's your answer. They are adjustable height.
I did not even know that was a thing. Amazing. Ill be interested to get in there and find out if its maxed out or not.
Very cool!
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
