Just wanted to share my experience, I got the "service parking brake" message awhile ago, it's just a parking brake. 🤓
I have the Ford/Allison MGM 10L1000 transmission so I need to get the truck to the dealer for the software bailout (N242454440). But before I do that I wanted to get all the DTCs cleared and such, last thing I need is the dealer telling me what they want a few $k for a parking brake job, I am strong believer in the right to repair. Alldata lists 2.4 hours of labor for both wheels.
I had an XTOOL AD20 Pro OBDII scanner quickly on hand and I pulled:
C15DD-00 Parking brake excessive wear detected Brake System Control Module (BSCM)
C15DD-00 No description found-Electronic Brake Control Module (EBCM)
I went to O'Reilly Auto and the shoes that they have listed do not work with this model truck. At the time written, the model number does not match, you can read my one star review with a picture of the OEM one here:
https://www.oreillyauto.com/detail/c/brakebest-select-brake-shoes/brakebest-select-brake-shoes-9-inch-bonded-brake-shoes/bgs0/1050/v/a/149155/automotive-truck-2020-chevrolet-silverado-2500-hd?q=parking+brake&pos=0,
this shoe and the one Napa has listed too do not fit. The employee at Napa had a hard time finding the part number and he even brought the part to the desk and cut the plastic off so that we can compare to the OEM ones that I brought in. They did not match.
I order Powerstop B1117, I have used a lot of Powerstop brake products over the years without issue(s). And this was no exception.
I also have a Thinkcar 689BT bidirectional scan tool, this has been a great tool! I was having an issue with the driver side express window close feature not working when closing. I used the scan tool to fix this. I have also learned that the truck definitely has current draw while powered off. This was proven with seeing the the DTC B3883-01, I removed the OEM rear bumper and installed a Hammerhead bumper.
When I pulled the rear passenger side rotor off, the shoe facing to the rear was down to the metal! I do not recall driving with the parking brake on! And I would think that the truck would warn you about the behavior! I found that someone else had a similar issue, https://www.gm-trucks.com/forums/topic/267997-service-parking-brake/
And as mentioned the brake shoes can be replaced without pulling the hub off, and be sure to have 45 degree needle nose pliers and other small picking and pulling tools, this is a PITA!
Using the 869BT I actuated the right rear parking brake, but I made the mistake of doing it with the rotor off and the actuator expanded to as far as it could go and an error popped up on the scan tool, “device limits exceeded anti-lock braking system solenoid valves or pump motor malfunction” and it did not retract. I am not sure if this is the way it was supposed to function, expand 1st and then retract? If this is the correct function, I suspected that it was trying to find the resistance of the rotor being in place and effectively engaging the parking brake 1st and then releasing. This make sense because I recall reading that the system time to retract (2.5 seconds?) is monitored and if the time is exceeded the DTC is set. So if you get in this situation pull the actuator motor off use a T-40 torx to retract the actuator, I had a Dewalt right angle drill that helped with this. Once the shoes were replaced I tested my theory by actuating the right rear parking brake with the rotor on and it did apply pressure 1st and then retracted. Started the truck and applied the EPB on and off three times, the error cleared.
Yes, I still have the driver side shoes to replace, but it is just a parking brake and now I can the truck off to the dealer for the recall fix.
Before I ordered the Powerstop shoes I called around to 4 dealers and non of them had the shoes in stock and I was told that it would cost $130 per a wheel. I paid $31.99 for the Powerstop ones and they came with new retaining clips, the O’Reilly and Napa ones where shoes only in the box.
While having the truck on without the engine running I noted the voltage was low, the Thinkcar scanner shows real time voltage when connected, is was as low as 11.58v. So I added an onboard Noco2D charger, the truck does a lot of sitting, I have “Dad’s ski wagon”, a 2002 Subaru LL Bean Outback that keeps the mileage low on the truck.
Torque values from Alldata:
Rear brake caliper bracket bolt 221 ft lb, I cleaned the threads and add Loctite 242
Parking Brake Actuator Bolt 106 in lb (round up to 9 ft lb)
Parking Brake Actuator Splash Shield Replacement – Inner 16 ft lb
Edited by digger86
 Very good write up on EPB, parts, and replacing shoes.  Details and pics are important and appreciated for the average DIYer.  Thanks for the post!
Good writeup, my 2020 LTZ was done 3000 km ago, after market shoes, pretty much same story, dealer wanted $1500. My mechanic did it for just over $600.
Xy74, my parkbrake shoes separated from brake material, i had never used them and the bonding process let go. I wish supplier's would bring back brake material riveted to metal shoes.
An isolated flaw no doubt......... according to GM.  :)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
