When using a fixed hitch towing my boat, I was using a 3" drop. Truck isn't lifted and will remain stock. Looking to buy weight safe aero hitch and debating if I should get a 4 or 6". My main concern with the 6" is when I go on curve with the potential of the hitch bottoming out.
I don't tow multiple trailer, it'll be just the one boat with the exeption of towing a uhaul trailer in the coming months. Any reason to get the 6" if I don't ever plan on lifting the truck?
I cannot speak to the Aero hitch but I have a stock 22 Sierra with a B&W Stow and Go hitch with a 4.5 inch drop - I tow a horse trailer only and that hitch provides more than enough adjustability for me. My hitch has bottomed out but only on an extreme driveway or curb. On my vehicle, 6 inch would be too much - just my two cents.
yes it was, measured from ground to hitch then level the boat on jacks then measured again and took the difference. That's how I got to the measurement as I remember. It's been awhile but short answer is yes it was level.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,440 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
