Whats engine redline for the 6.0L?
WOW! I hit 5k once and I started to cringe. I just kept think shift dang it! Shaners- 5K when towing were you trying out for the Quaker State commercial. I don't just baby my truck compared to you guys I nurse, pamper and caress it, it's a wonder I don't pull it around. But you are a testiment to GM longevity :thumbs:
The 6.0L is an LS1 based motor. The 4L80 transmission is pretty low-shifting with the big torque converter and stock programming, but I think the motor could rev out to 6000rpm reliably no problem. You guys that are getting worried about the engine running up to 5k rpm towing a heavy load make me laugh. :D Keep good oil in it and warm it up before running it and then spank the sucker. :cheers:
Like QUIKAG says, these newer ls1 motors will take alot of rpm. They have a pretty stout bottom end. Above 6000 i might get worried as the valvetrain on the trucks in not the same as the camaros or corvette. I will say after 5500 it does start to sounded very wicked. But i run it up that high at least every other day. I put my shift points at 5650 in first and 5850 in second.
My spec sheet for Model Year 2002 Sierra shows the 6.0L, "Maximum engine speed (RPM) -w/ manual transmission" as 5600 RPM and, ". . . w/automatic transmission" as 6000 RPM , with the following footnote reffering to the automatic tranmission versions. "Maximum RPM 5900 with optional Electronic Traction Control (ETC)."
:cheers:
Yeah, the only problem with rpm I can see would be the valve springs and possible valve float. Anything under 6000rpm, with some good oil and good operating temperatures, you could probably sit at 5000rpm for a long time with no ill effects on the motor.
I keep the LS1 in my '01 C5 above 4000rpm and close to 6000rpm for a long time at full throttle for 30 minute sessions when I'm roadracing. Oil temps get close to 300 degrees and the motor just sings all day long with the Mobil 1 synthetic.
These are stout motors, they like revs to build power.
