2020 Silverado purchased used April last year. Everything worked as expected until December (in Michigan) when fobs stopped working intermittently. Vehicle starts and runs normally when fob is in pocket. Fob batteries tested good but were replaced with new. Mechanic friend suggested battery load test (Michigan winter is the time most of my batteries have failed in the past). Load test revealed failed battery (factory original). Battery replaced and all problems resolved until about one month ago when fobs would fail intermittently as with problem last winter. Battery tested good. Fob batteries tested good. Noted low voltage on DIC voltmeter. Alternator tested bad. Alternator replaced with satisfactory charging now showing on DIC. Fob issues persisted for about 3 days then suddenly disappeared. About one week later fob issues returned and "Service Tire Pressure Monitoring System" displayed on the DIC which would then vanish. TPMS is working as it should when no alert displayed. With fob in pocket the truck starts, runs, and all electrical functions are normal. Pulling battery terminals and shorting together for residual voltage drain was performed too. Intermittent "No Remote Detected" displays on DIC when starting with fob in pocket.
Any suggestions will be greatly appreciated.
Sounds like a fault with the remote control door lock receiver or in the wiring circuits to it.
I have been trying to figure out how to troubleshoot the remote receiver and associated wiring...
alldata.com for wiring diagrams, connector pinouts, diagnostic procedures
a more advanced code reader that can access all the computers in your truck, including the rdclr.  Not cheap. a good j2534 obdii-usb passthrough device, a windows laptop and finding GDS2 software on the internet would probably be the cheapest way
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
    • Rockauto bud. I pass local stores for parts.   Findya something online.
