Just so all know its the 2024 Chevrolet 2500 HD 6.6 gas that we have
Since new when I use the remote start feature the truck starts just as if you were starting it from in the cab but there's a strange noise that sound right after it starts . Its really hard to explain almost a loud whrrring noise or maybe as if its traying to start again although the engine is running . Is this normal ? Have you noticed anything similar   ?
I do have to take it in for a check up so maybe I mention it then
Thanks
I don’t notice any different sounds when I remote start versus normal start my 2021 gas 3500.
Okay Thanks for the replies !
Going into the dealership on Friday see what they find out . Meanwhile any others have this issue ?
My 2020 gas almost always made a ratcheting type noise that lasted for a half second a couple of seconds after start. GM blamed it on the oil pump and said it was normal.
This may be what the OP was hearing that caused his concern. The oil pump cavitation noise on a given start is the same regardless of whether the start is initiated normally or remotely, but it sounds different if you are outside the truck versus inside.
Thank You !
Thanks JR So maybe I have the better half start it from the inside and see if I hear the noise from the outside like I do when I start it remotely
I have taken the truck into the dealership to see what the problem might be . Well it would not make the noise after repeated remote starts . So Its only when the truck has not be driven beforehand .  So the dealership wants me to take a video of it starting from a cold start to see if they might be able to figure it out or leave it overnight and they try it in the morning
  • 11 months later...
Update to this issue as I have now 2 seprate threads on it . JR has graciously offered to help me out by posting a vide of the starting of a 2024 2500 HD  6.6 Gas so I may see and hear what his truck sound like when starting
If any of you fellas have the same truck and would care to video a cold remote start so I can tell if it is similar to my it would be appreciated
Thank You
Here we go Ryan and others the exact same sound my truck makes . Is this the same noise you experiance JR ?
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
