I’ve researched this for 10 years and I finally got around to doing it. Nothing on the Internet seems to help.
This is a 2015 GMC Sierra 1500 WT
So here is the deal there are 6 wires that go to the camera.
IMG_6434.thumb.jpeg.b2d6ebf5860d6465486d5feca10d23c7.jpegRed, white, yellow, brown and 2 blacks
Red wire is constant 12+ volt.
White wire is 12+ volt while in reverse.
If you apply an external 12 V source to the white wire the backup lights do come on, but the camera doesn’t. If you cut the wire, you can eliminate the backup lights, but the camera still doesn’t work.
The yellow, brown, and two blacks have no voltage or negligible voltage, whether in reverse or not.
I’m assuming my problem has something to do with one of the two black wires but I don’t know what it is.
What am I doing wrong/missing?
The goal is to install a diode, so the camera works in reverse and when a button is pressed in the cab. I already have a wire in between the cab and the Camera. But that’s pretty useless until I figure out how to trigger the camera on… I’m going to take power from the driver side fuse panel, where I have my other accessories connected so it’s only live while the truck is keyed on.
Help would be appreciated.
Edited by MGnoob
Why would you expect the camera to tell the radio when to flip into reverse mode?  I expect the radio receives a digital signal from the ecm/bcm telling it the truck is in reverse, then the radio goes into reverse mode and turns the camera on.
I would expect it to be non-trivial to get the radio to switch into reverse mode on command.
But, if you really want to find out, a subscription to alldata.com should be able to tell you what all the wires to the camera plug are for.
I feel like it would be easier to just do the live view rearview mirror the hardest part of figuring that out is how to mount the camera. It you have auto dimming drivers mirror you'll already have power to the rearview mirror you'll have to get a mirror from a 2020+ truck and you'll have just the camera wire to run to the back of the cab. If you don't have auto dimming drivers mirror then you'll have to get a harness from harnessdr.com. all in all way easier then what your trying to do.
That’s not a bad idea. That is what I’m trying to achieve. I have a cap on the back of my truck that completely blocks my rearview..
You can get the camera cord on Amazon it comes in several lengths.  Camera and mirror is off a 2020+ truck.
Cord link
https://a.co/d/g1R6T7s
Mirror needed
https://ebay.us/m/sW8Yqd
Camera needed
https://ebay.us/m/iNwqHp
Edited by Homewrecker007
  • Thanks 1
Why would a wire from the camera that is triggered by reverse lights, not turned on the radio view? what purpose would it serve?
I have read there’s a 20 pin connector behind the radio that you can work with, but that’s for upgrading to a new radio/viewer.
they sell kits that you plug directly into the camera that jumps the remaining 5 wires together, but then it only has an RCA, which is video and ground that you plug directly into your new radio. I would just cut that off and connect it to the existing wiring but that my not work. My radio has no option/menu for the camera at all.
I should attempt to try jumping the remaining four wires that I’m not working with together
not the red or white though and see what happens if anything it would leave me with the camera/video monitor constantly on. then I would just interrupt the power on the red to turn it on and off.. I would lose it automatically coming on when I put it in reverse.
I’d still like to get the rear camera to work similar to the way I’m doing it, but I guess I could always go cheap like this..
I don’t think I have any power up there, though I guess I’d have to figure out how to route it
I guess with the adapter from Amazon and the camera package from eBay I have both cameras on my rearview mirror. I can probably make it work so that the factory system still works.
I added all the things you need for rearview mirror setup. I put this in my 2014 and my 2018 sierra's
https://ebay.us/m/5OXvOD
I’m dumb. I should just buy this. I’m operating off of what I tried to do 10 years ago. I didn’t realize I could just buy this. I’ve recorded front and rear view. Forget the factory system.
i’m gonna look into these and the OBD-2 options…
if anyone knows how to make the factory one work the way I want to please tell me.
this is similar to the controller. I got for the LED light bars. This modern stuff is great.
You can also upgrade your radio HMI to allow carplay and android auto and then get this adapter harness so you can push a button on your radio screen and turn on the backup camera while driving down the road.
https://harnessdr.com/product/2016-2019-silverado-sierra-reverse-camera-adapter-harness/
https://www.whiteautoandmedia.com/product/car-play-upgrade-retrofit-kit/
I just gave you the 2 easy plug and play options that everyone does. And have personally done myself.
    • There's some truth to the above, but also, she's selling fullsize trucks and bread/butter CUV's like hotcakes, meanwhile, extracting GM's pickups from the deep discounting sales game.   GM's stock has held its own during her tenure, and the more recent buybacks are delivering cash back to investors and signal confidence in their direction forward. Even with the EV losses.   GM is an example of a modern publicly traded company. The #1 goal of any publicly traded company is to deliver the most value possible to shareholders. Despite being a car company, building the best car isn't GM's path to delivering maximum shareholder value.   McDonalds doesn't make the best burger, or the best coffee.   I've mentioned in another thread, I really don't / won't ever understand Cadillac or Buick in a modern context. Both brands are completely dead to me. I'll cede that the Escalade is a nice SUV, but the brand and nameplate mean nothing to me, and GM will never persuade me to pay north of $170k for a gussied-up Tahoe or Burb. Other people don't mind doing that and that's their purview.   The C8 shares absolutely nothing in common with any other current Chevrolet or Corvette on the market. Since its introduction 8 years ago, it's developed quite the following. It did what other Corvettes couldn't do: reduce the average age of its buyer. GM has something there, and I see them investing in the car. They'd better not mess that up.   We've successfully derailed Grumpy's thread again, but I think this one is meant to be more of a random thought thread so a little wandering is probably OK.
    • Sliding doors ftw   Also, Sienna ftw as well.  The in-laws got a 2024-2025 recently when their 2019 sienna was totaled due to a deer back in June.  They've been getting 38-40mpg on the 65mph highway they live on.
    • Forgot to mention that this started after changing the oil I use mobile 1 full syn with mobile one filter but I did add pro lube additive and was the first time doing so and is making me wonder just can't see why that would matter
    • I apologize for long post put going to try to explain everything. Parts replaced so far: Cam sensor Crank sensor Cam phaser valve Cam phaser solenoid Fuel pump Maf 1 injector Pcm Pdm   So about 2 weeks ago coming off the highway my 2007 yukon xl with the 6.2 stalled and would restart. Had unit towed back to house and I messed around with relays and unit started. Drove it the next day and same thing. Had it towed again. Scanned unit and had code p0300 with misfire data showing mainly cylinder 7 but I know that won't cause a no start. Measure fuel pressure and found only 42 psi replaced pump to have unit stall again and not restart. This time I stayed on back roads and just waited for it to restart about 30 to 60 min. During this time I found I have no injector pulse but have good power at injectors. Started unplugging 1 injector at a time and found when unplugging cylinder 7 pulse came back so i changed injecto and same issue. Turns out unit just happen to ready to start at that time. Scanned into unit and found no reason for the pcm to take away injector pulse so I replaced the pcm and same issue. I figured timing sesnor controlled the injector pulse so I replaced both sensors and while I had the water pump of i replaced the vvt components while i was in there. Read multiple people have luck chaging the maf for this issue so I changed it. Unit still stalls to this day and loses injector pulse on the ground side when it does. Have noticed watching the live data the pcm is request injectors to fire via injector pwm value. I have redone the ground wires at the left bottom of the block knowing this was the ground location for the pcm but still no luck. I am a mechanic by trade but this is having me pull my hair out. If anyone has something to have me check I will gladly im not much of a parts thrower but im about to load the cannon
    • Actually.  Wait.   I just re-read your original post.  Are you talking from INSIDE the truck you have to hit unlock?  Or from the key fob?  I had assumed from the key fob.   IF you are talking the inside unlock button, I assume you are shifting to park and its not unlocking the doors?  If so, that is changed via the settings page in the radio.  Go to SETTINGS, then VEHICLE and then it should be under LOCKS or DOOR LOCKS or something like that.
