Rear trailer camera has been working great for 1 1/2 years. on last two trips, started acting flakey. It will go on and off constantly almost looking like it was a bad connection that was happening when I would go over bumps. Now it doesn't work at all
Did some tests with my wife in the truck and me wiggling the connection on the bumper as well as the wire going into the camera but could not get the camera to turn back on.
I have also cleaned the connectors with contact cleaner with no success.
Anybody else have issues with their rear trailer camera like I am having? Was it the camera or the truck?
I would really like to find someone with a similar truck to hook up to my trailer but finding one is going to be tough. Not sure if I should take the camera off the trailer and bring it to the dealer or just bring the truck in. My dealer has no room to bring both in unless I find a different dealer with more room.
Our team would be happy to help you find other dealerships in your area, Bruce. If you're interested, please reach out to us at [email protected] with your full VIN, full name, zip code, and mileage and we can get started. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
  • 4 weeks later...
These trucks use "hacked up" Pulse Width Modulated DC going back to the trailer connection for the trailer lights. The camera uses the same PWM DC voltage to power your camera.
You can purchase a PWM filter in between your camera and your camera connection. You can get these filters on Amazon for next to nothing.
Also, make sure your camera monitor is not set to cycle between camera's. It needs to be set not to cycle, i.e stay on the same camera without trying to cycle.
Edited by viking59
This makes zero sense. Why would I put PWM filters on a factory trailer camera?
Also, there is no camera cycling.
Edited by bruceb58
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
