JimCost2014 Posted January 26 Posted January 26 On 1/23/2026 at 11:01 PM, mikeyk101 said: I am using similar ones on both my toy hauler and my cargo trailer. They also monitor the temperature along with the pressure. Those are Tire Minder and work quite well but I have to use a special receiver that I mount to the windshield to monitor them. On my Honda trike I am using FOBO sensors but I have to use an app on my phone for that. That also monitors the temperature but gives me the battery level too which is nice. And the big advantage on the Tire Minder and the FOBO sensors are that the batteries are easily replaceable. But both systems are like you say, big, ugly caps that replace the valve caps like yours. On my Silverado, one of the big pluses was that the sensors are internal and not visible. I can then just look on the DIC to see the pressure of each tire when I want and don't need a separate receiver or app to do it. One thing that I find lacking that I see on yours is that it also shows the temperature as well. I wish the OEM style sensors offered that information. Think the temp info is probably vehicle specific. You just put these on the valve stems, put your truck into learn mode, then walk around the truck with the GM specific tool in the picture (comes with kit, and I already had one), touch each sensor until the horn honks, on to the next one, when you are done with all 4 you get the double honk. TPMS light goes off on dash, pressure shows up again in the DIC, and even shows on the OnStar app. 2
mikeyk101 Posted January 29 Author Posted January 29 Well it's almost a done deal. I'm at Discount Tire having the new Shrader TPMS sensors that got delivered earlier today installed. I'm also having the balance checked on each wheel with their road force balance machine. The TPMS install is $25 a tire and balancing is no cost. Had the weather been a little more decent, I might have attempted the tpms swap myself but it's just way too cold to attempt. I should now be good for several more years. 3
Register a new accountSign in
