Hey everyone! I have a 2021 Silverado High Country with the factory LED lights. My taillights are factory, and have just been tinted. Recently, my passenger side taillight has been flickering on and off, and I get a hyper blink when I turn on the signal. It was working some of the time, now it doesnt work at all.
I can get a single faint light on top, and the break light works but the DRL and blinker doesn't.
I had moisture in the bezel, so I drained, dried, and sealed the bezel. I have dielectric grease in order to help connection, but everything looks good... after testing with mutimeter, I believe I have a bad ground, but cannot locate a single ground wire on the truck.... can someone please help me locate the ground wires so that I can clean, and put back together with dielectric grease and see if that will fix it. I think it is wiring and not the light itself.
Driver side works as it should, so definitely an odd issue. Any help is greatly appreciate!
you might find enough of the wiring diagrams and ground locations on gmupfitter.com for your truck.  otherwise I would suggest a subscription to alldata.com for it.  15% off right now using code WINTER15
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
