My 2019 6.2L will sometimes have a brief stumble when it’s cold. The first few times I thought it might have been traction control kicking in when pulling out onto slick roads but it happened today when it was idling after remote starting it. RPMs just fell for a moment, and then it took back off and was fine the rest of the day. Runs perfectly otherwise.
Don't ever recall this happening prior to the past two months or so. It’s happened maybe 5-10 times since then.
Any thoughts? No CEL and no codes when I checked the other day.
Only specific thought I’ve had is maybe a fuel filter? AI suggests a MAF sensor cleaning which seems maybe reasonable?
Edited by relevante
It was definitely a little gummed up. Time will tell if the stumble happens again, but it sure does seem to be idling smoother now. The first time I pulled up to a stop sign I thought it quit running. Thanks for the tip.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,373 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
