Hi im nate new to forum.  I have an 05 colorado 4cyl standard and the ac compressor clutch won't engage.
Fuse is good, relay is good. If I take the relay out and jump across relay clutch engages. Does any one know why im not getting power there.  I checked the pressure sensor switch 5v on 1 wire
Good ground and when I check the last twire it beeps ground fast like beep beep. Etc if u have a power probe u can understand what im talking about. I tried to jump pressure switch but dont know  if im doing it right
Please help I cant afford to pay someone to chase wires and track it done.
charm.li (website) has wiring diagrams, connector pinouts and diagnostic procedures you can use to find what the problem is.
It's possible the ac pressure sensor isn't working right, or is the pressure in the ac system is too low for the clutch to engage (just some common things, it could be other stuff as well).
Just more on first post i disconnected the ac compressor and just hooked up a light. The only way I could get the light to come on was to jump the relay. I
 Dont know alot about elec. Diagnosis so im not sure if this would work because of the pressure sensor if anyone knows please let me know ow.
On 5/9/2026 at 11:51 PM, Griffco77 said:
I Dont know alot about elec. Diagnosis so im not sure if this would work because of the pressure sensor if anyone knows please let me know ow.
The relay isn't powering the clutch because the computer is telling it not to. Likely because the refrigerant charge is low and is protecting the compressor.
It will need a set of pressure gauges to confirm a low charge.
Then the cause of the lost refrigerant would need to be found and repaired. Followed by vacuuming the system down and adding new (correct amount) refrigerant.
If you have confirmed the refrigerant charge is correct, the only reason for the relay not to power the compressor is the relay itself is bad or bad wiring. In the case of the latter - you will have to manually trace the wires looking for faults. If you're lucky you might find something obvious like rodent damage. In any case, the likely problem is low charge.
The old compressor was bad put in. New one put vacuum o it and confirmed no leaks. Went to charge and it would only take a little bit cause new compressor clutch wouldn't engage what do I do jump relay to get compressor going to finish filling. Filling by 12 ounce can it would only take maybe 4 or 6 ounces
Should I jump relay and get compressor going to finish filling.
The cans should be pressurized enough to 'push' refrigerant in, especially when the system is under vacuum where it should 'pull' the refrigerant in.
It is a careful sequence of operations to suck down the system and add refrigerant while maintaining the original vacuum and replacing it with only refrigerant. All while not allowing atmospheric air to enter.
Having a digital scale handy to measure the refrigerant can before opening it and after to make sure the correct amount of refrigerant entered the system. Proper charge is determined by weight - not volume.
Presumably, you are using the proper gauges and vacuum pump necessary.
Edited by asilverblazer
    • Maybe, but it seems he is the only one that has backed up data to prove what he is stating. I think he is doing this more because he enjoys it and wants to get the information out to us. He's got the knowledge and access to the proper equipment and having the funds doesn't hurt.  I would love to do what he is doing and would do it if and when I hit the Powerball.  I'm not a Tribologist by any means but love to learn what I can.   I would bet there would be doubting people out there if a completely independent lab with high quality work and highly respected in the automotive industry, put out information like this.  The world can't be pleased, one just has to take the information that they are given, do more of their own research to find actual lab data to back up what they are trying to figure/find out.  Most don't bother, they just want to believe what they first see.     I don't have the minimax but my 6.2 in my 2019 Silverado with 64k miles shows excellent UOA results with 0w-20 and for my own purposes 5w-20.  Since not much of a change using 5w. I liked the data sheet information on the SS 5w-20 and figured I would give it a try.  Still the same viscosity at 100℃.   In the end we all just do what makes us happy, life is too short to get upset over trivial social media.   On a side note, I do feel GM has dropped the ball and just cares about the bottom dollar and not quality anymore.  "Like a Rock" has been long gone.  Seems "Built Ford Tough" has as well.
    • Better than stock but that's like putting lipstick on a pig
    • Hello, my 3 month old Sierra Elevation wont recognize a trailer with electric brakes? All the lights work correctly, but no power to the brakes?   This is the factory installed brake controller. If you manually push the knob, the display shows the power % but does not light up like my 2022 silverado.   I have an appointment with the dealer, but was checking to see if anyone else has seen this issue.    Thanks,
    • Been using SS 0w-20 from new, but wanted to change to the 5w-20 because I liked the data on the data sheet, to me it seems like a little better product. But as you can see, not much difference. This is also with running a mix of 10 gallons E85 to a tank topped with 93. It isn't a flex fuel vehicle so any higher I get a CEL for running lean on both banks. Yes my mileage takes a hit. Instead of 20 mpg I normally get on trips I get 17mpg. This is also using EaO17 filter.  What is amazing is I have the AMSOIL cone filter on it since I have the GM Performance intake installed and that air filter has 44k miles on it.  I just take it out and shop vac it off once a year.  I use the upholstery tool on my shop vac.  Works well.
    • So, lot's of googling and reading, and a trial fit found, that indeed they hit the newer fatter caliper. I did some re-testing today, and found just 3/16" worth of washers was enough for the wheel to spin freely. I added 2 more on each, and again it spun freely. Tested lock to lock with the 4 washers, about 5/16" not quite the 3/8" Im considering, but pretty close. No issues. I've been looking at the BORA .375" spacers and using extended lugnuts to get back lost thread due to the spacer. All the ET lugs I've seen are all .33" reach inside the wheel lug holes. For those that don't like spacers or think they're unsafe, I think it depends on what type of spacers you're using and making sure you get good quality hubcentric ones, and if you're using bolt on ones, regular mainenance, checking the spacer lugs. Not wanting or needing that much spread. Looking for the minimum that will let me run these rims and tires.  it does look to stick out a little, but I really want put these on. and use the stock all-terrains in the winter.
