What exactly is happening when this mode activates?
Is fuel cutoff, or is it something else?
what are you talking about?  dfm uses one of 17 cylinder patterns, from 1 to 8 cylinders being active.  They don't use a pattern wih zero cylinders enabled.
0 cylinder mode?  That would be deceleration fuel cutoff via the fuel system.
Any time an AFM/DFM engine enters DCFC, all cylinders go back to being active.  So the DFM solenoids close the oil flow to re-lock the lifter, and all 8 cylinders become mechanically active again.  Engine pumps on all 8 but they cut the fuel off.  So extended coasting (down a hill, long offramp, if you like to save brakes, etc.).
DFM can skip fire on as little as one cylinder.
Quote
The conditions listed below may be reasons for inhibiting deactivation:
  • Decel fuel cutoff is active
Deceleration Mode
When the driver releases the accelerator pedal, air flow into the engine is reduced. The ECM monitors the corresponding changes in throttle position, Mass Airflow (MAF), and Manifold Absolute Pressure (MAP). The ECM shuts OFF fuel completely if the deceleration is very rapid, or for long periods, such as long, closed-throttle coast-down. The fuel shuts OFF in order to prevent damage to the catalytic converters.
Fuel Cutoff Mode
The ECM cuts OFF fuel from the fuel injectors when the following conditions are met in order to protect the powertrain from damage and improve driveability:
  • The ignition is OFF. This prevents engine run-on.
  • The ignition is ON but there is no ignition reference signal. This prevents flooding or backfiring.
  • The engine speed is too high, above red line.
  • The vehicle speed is too high, above rated tire speed.
  • During an extended, high speed, closed throttle coast down—This reduces emissions and increases engine braking.
  • During extended deceleration, in order to prevent damage to the catalytic converters
Here's a great detailed read from GM/Tula Technologies.  Tula is the one that actually created DFM, originally called Dynamic Skip Fire by Tula.  GM bought into Tula to get DFM into the updated Gen V engines.  @Grumpy Bear You'd probably love reading this if you haven't.  The list of side effects are rather interesting, and some of them came to fruition with AFM and now DFM (torque converter problems being one of them).
Dynamic-Skip-Fire-New-Technologies-for-Innovative-Propulsion-Systems-Paper-Vienna-2018.pdf
Edited by newdude
  • Thanks 2
Thanks for the info @newdude. Does this mean that it is not the typical DFM mode of collapsing lifters that is used to turn all eight cylinders off? Or does it mean that 0-cylinder mode, correctly labeled as Deceleration Mode, is simply DFM affecting all eight cylinders at the same time? Are all lifters collapsed in this mode?
edit: I read what you said more slowly.
Closing the oil flow. This puts the lifters in non-DFM mode? Just as they would be if the engine is under load and pulling, but the cylinders do not fire because fuel is cut?
Edited by TrueBlue
In DCFC, all 8 cylinders are active.  The lifters are not collapsed allowing for deactivation.
In AFM/DFM lifters (same exact part), when oil pressure is applied to the internal locking pin, the lifter is allowed to collapse and perform cylinder deactivation.  When the solenoid closes, that oil pressure bleeds off quick and re-locks the pin, thus allowing the valves to be open and the cylinder is no longer deactivated.
  • Thanks 1
Thank you Sir. In my case I think this is a good thing.
Do you happen to know whether or not DCFC is deactivated, along with DFM when in L9?
Edited 11 hours ago by newdude
Serious complexity. Great read and thanks for the share @newdude
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 1 Anonymous, 647 Guests (See full list)
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
    • This landing is worse than most. Patchy blacktop with washouts, soft gravel/sand at bottom that washes out with every heavy rain. I tell everyone to put it in 4WD. A lot of them think they can pull out their trailer in 2WD. They end up digging a hole and then putting it in 4WD.  The lake is a pristine lake and has a lot of money on it. There are several wake boats and lot of large tritoons. The people with the money don't want it improved because they don't want more traffic.    Boat Landing 1.jfif Boat Landing 2.jfif Boat Landing 3.jfif
    • How wide are your rims?   Toyo specs 8.5-10.0-11.0 inches. My thought would be rim might be pulling the tire inwards creating a center that is more pronounced.    I also noticed that the spec sheet says max 65psi. So you could be right lowering the pressure to ~40 psi.
