Hi everyone, looking for some input on an issue I’m having with my truck.  It’s a 2016 2500HD Crew Cab LT with the 6.0.  A couple of months ago I had the pitman/idler arm and tie-rods replaced at a shop with some good quality parts and then professionally aligned after that.  Immediately I noticed that the steering is much tighter/heavier feeling and has zero play of any kind.  However the steering will not “return to center” at highway speeds now, for example if I’m going around a slight curve with the wheel turned and I let go of the wheel the truck will continue to turn instead of the wheel re-centering like it used to.  It makes it so I’m constantly fighting to keep the truck going straight down the center of the road.  I should also note the truck does have the “NV8” electronic steering assist.  I’m wondering if I need to have the steering control module re-programmed?  Or is it an alignment issue?  All of the alignment parameters were in spec from the shop.  Maybe someone else has had this issue, I appreciate any feedback, thanks!
It wouldn't hurt to get the module re-flashed. Usually only needed when module is replaced. There is a specific procedure to learn the steering angle to the module, that may be off now that the alignment is different. Usually only see it after replacing with rack, or module replacement and they throw DTCs when not learned.
Sounds like the alignment isn't right.  And or they messed up something on the box doing the pitman arm?
Can you post a picture of the alignment printout showing the before and after?
Edited by newdude
Thanks for the reply’s everyone.  I will try to find the alignment printout and post that up.  Sounds like I’ll be taking it back to have the alignment re-checked
It is our goal to ensure you feel confident and in control while driving your Sierra. We'd like to know more about this as soon as possible so we can provide our layer of assistance between you and your dealer to address the steering concerns. Have you taken it in yet since this post? Please fill out our support form with more information, your username, and forum name so a member of our care team can reach out to you: https://s.chevy.com/support-request
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
