I have a 2020 Sierra with the electronic latch. Can I switch that out and put a regular latch in.
No.
Great question, Jim. To be sure, we recommend connecting with your GMC dealership for advice on if switching your latch could work for your Sierra. Are you experiecing concerns with your current latch? If so, please fill out our support form with more information, your username, and forum name. A member of our team will follow up with as soon as next available with assistance. Support form can be found here: https://s.gmc.com/support-request
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
