6 hours ago, Atlas said:
Because I couldn't find someone to do a root canal without anesthetic on me, I decided to replace the door pins on my sagging driver's door to fill my Sunday afternoon instead.
Nothing makes a vehicle feel more like such a huge pile of crap than a sagging driver's door, especially when it creaks/groans. Procedurally, it's not that hard of a fix. Practically, it is a learning curve and you really should have someone there to help position the door when it's unhinged. Caution: spouses may become unhinged if you don't clearly communicate expectations or start moving the door without announcing to line up holes, etc.
I'm happy to report the hinges are just fine, but the old pins were severely worn, and the bushings had basically broken they were so bad. New pins and new bushings have it opening/closing level with the striker. These are pretty janky doors/latches from the factory so we don't get a "pop/thud" open/close like with a Mercedes. More of a clacky/latchy sound with a jiggly door handle. But it's as-new, good as it's going to get.
One more item checked off the list. The passenger door "could" use a new set of pins. 50/50 on whether I do it or not as it's fairly involved. At the very least I'll wait a week because I was down on my hands/knees and I'll need to wait a few days to recover from that!
I'm free and FREE to do that root canal :crackup:
  • Haha 1
I have an old dental chair in my shop. Something I got for free and apparently it has more than scrap value? People collect them although mine isn't restored or anything. It's visually interesting (1930's Ritter) which is why I like it. And it IS decently comfortable if you kick back.
When a good buddy of mine saw it he said, let me guess, Atlas. It's a conversation piece? As in, you ask the questions, they do the talking?
Where do you hide the jar of teeth?
I would never.
  • Haha 1
I would never.
Why does that not surprise me? 😏 It is more creative that a crowbar on a kneecap. :crackup:Did it come with the mounted overhead lighting? 😬
My office is slowly filling with Blazer parts. Getting ready to do the big bang of repairs. Intake (second time), water pump, radiator, hoses, and I'm going to re-seal the timing cover where someone went hog wild with silicone. Might as well, because I don't think that's done right.
There's a local tow yard that I didn't realize also has quite the inventory of junk vehicles. This is an old school junkyard. No waivers. Cash only, you were never here if anyone asks. Don't piss off the owner, or you'll end up in the back of one of those cars, headed for the shredder. And if you see something, don't snitch. Cars stacked double high, wasps nests, trip hazards and junk everywhere. I found a few little odds/ends for my Blazer. The $20 I spent was worth the experience alone. But I was never there. What yard?
I officially love/hate this truck. It's so out of my wheelhouse, roughest vehicle I've ever owned. Every. single. repair. -is so hard-fought, everything that can go wrong, goes wrong. Currently in a hate phase, and kind of wish I was closer to sending it down the road with a lucky new owner, to be honest. Preparing for the day when I tear into this thing...lots of pre-funk with Ibuprofen.
Rock Auto sent me a bad reman rear wiper motor. It was a bear to install. The tailgate in these things has about eleventy-billion fastners and pieces and things that need to be uninstalled/moved just to access the shoddy rear wiper motor. The casing on mine was cracked clean through, btw. Nice, GM, nice. SO I got this new motor installed, hit the switch, I see it wig-wag (without the arm installed) and think I'm golden. Reassemble everything. With the wiper arm installed I gave it one final test. Time to clean up and take the other half out to dinner, collect a paycheck, right?
Nope. I hear the plastic worm gear stripping as the arm hung up. Just like my broken motor. Weak/old and shredding itself internally. I can assist the arm and the range of motion is normal, and it parks correctly. It just doesn't have the poop to actually sweep the arm with a blade on it. Oh, hell. Turned the key off and shut the shop door behind me. I get to do that over again, too.
Sunroof on Dizzy was like that. Fix it, break, fix it again, break.. Fix it again RTV it shut. :crazy: Plastic gears.
Love yards like that and they are few these days. Going to the mall before there were malls.
    • Correct.  2019-2020 are serviced by a different p/n.  19420611.   The recall engines 2021-2024 are serviced with 12740076.     What the difference is between the two, I'm not sure, but 2019-2020 only show 19420611 as the replacement engine p/n.
    • Looking for advice from this group. Took my flawless 2020 6.2 TB to an unnamed shop for routine rear brakes and oil change. Tech forgot to put oil back in after the full service and needles to say, destroyed my engine.  It’s all on their shop video so they are responsible.   I had my Chevy dealer do the analysis and they confirmed its compromised and said engine replacement. The manager said they only get GM reman engines from GM with full 3 yr warranty and the one they would put in is not same as what’s they are swapping out on 21-25 for recall.    I am looking for advice why that would be a different engine because obviously I had the good 6.2 year and replacing it has my concerns with that recall for 21-15   Also what’s the pros and cons of accepting the engine swap vs telling the shop that bricked the truck to pay up so I buy a new truck. I’m concerned about stigma resale eventually if I just decide to get rid of it after the swap or other issues showing up after the swap out.
    • Just looked up my records.  I've never gone over 5000 miles between oil changes.  At 46K miles, I have 10 oil changes.  I hope that will help.  I also installed the disabler last year.  I've still had a few times when it didn't seem to engage (which I can tell because the start stop feature kicks in), but for the most part, I think it's working.  For some reason, GM did not include the number of cylinders running in the information screen like I had on other models.  In my Cadillac, it shows me when it's running on 4 cylinders on the fuel milage screen.  I can't find that on my '21 Denali.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
