Hello GM
I will now post this here as I did not know there was this thread . I have a 2024 Chevrolet 2500 HD Custom 6.6 Gas engine built  in Oshawa
When starting the truck remotely you can here the initial startup as any vehicle would start but right at the very end  of the start and engaging there is a strange noise it is very hard to describe but it is different . Some are suggesting this is the purge of air from the oil pump and the start of delivery of oil to the engine .
Can you verify if this is in fact what is going on  ?
Here  is a video of another truck with same noise as my truck
Thank you !
Edited by BCGM
If you have air in your oil pump, your engine is on borrowed time. That should NOT happen EVER.
What that sounds like to me is the starter spooling down from a high RPM coupled with the drive gear retracting back into the starter. Stuff like this they used to take the time to engineer out of components ... but these days that kind of quality is a 20th century relic, so this is what you get.
The sound reminds me of those toy cars I had as a kid that had a flywheel and spring inside - you would rev them up by pushing them along the floor until you heard that flywheel spinning at a high RPM, then you could let the car go and it would shoot across the floor at 20 MPH, launch of jumps, smash into furniture and walls.
There was a point where you could get the RPM of that flywheel so high that it would go FAR out of balance. The whole car would make that exact sound, and the high RPM would bleed off SUPER fast due to the imbalance. Sounds exactly like what is going on with the starter. Just my educated guess anyway.
Okay having said that is this a normal noise ?
Did you happen to see JR's explanation as to what he thinks is going on in my 2 other threads . Of course I'm not trying to stir anything up here between opinions I just want to know what is going on with the truck
I honestly have no idea. These days I don't work on anything built after 1994. Based on what is shared with me from those still in the industry, this is par for the course - noises, rattles, ticking, etc..
Probably better posting that in the 2024 truck forum so fellow owners can chime in with their experiences. This section doesn't get as much eyes on it.
Edited by Jsdirt
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 443 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
