Depends where you're going to be towing.  I have a Grand Design 2600RB, which we roll heavy when we go cross country.  Into a wind above 5000 feet elevation, it struggles to keep the RPMs down and gets absolutely abysmal mileage.  How fast do you like to drive?
The truck handles the trailer beautifully, and the engine is great below 2000' in nearly all conditions.
2024 2500 LTZ crew cab long bed 4x4. We pull a 5th wheel, not a bumper pull but regularly pull horses in a bumper pull trailer as well as a gooseneck. Our 5th wheel is 11,000 pounds GVWR. We've towed about 10hrs on the longest trip - after a mile or two, forgot the camper was back there except for going over bridges with a dip that gave a small bit of a bounce. Same will any horse trailer we pull (probably 8,000 at the most) and we don't even realize it's back there.
I wonder what I'm doing wrong whenever I hear people say they "don't even feel it back there" when towing 10k+ lbs. I could even feel my old 3,500lb travel trailer. Oh well.
I have a 36' bumper 9k FR and unless it's super windy, the only way you know its there is when rolling out from a stop.
That much weight is over double the empty truck. Sure the truck can handle it well, comfortably even, but it significantly increases braking distances regardless of trailer brakes and slows acceleration and adds significant surface area to a wind. "Not noticing it" is a huge exaggeration. I'm sure you feel it every time you stop, change lanes, accelerate or hit a bump.
Edited by chris21
  • Haha 1
The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.
With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
