What are your thoughts? The Chevy Blazer relaunch was an epic case of 'lunchbag letdown'. Jeep Wranglers and Ford Broncos stick out like a sore thumb.
The AI photos do not look like a 'retro version', but shrunken Tahoes. Get away from the 'futuristic look'. I've seen two concepts. One had rectangular headlight like a Rivian and the other way too big headlights (similar to a previous non-Wrangler SUV) should include dual round headlights like the early version.
If not this would look OK
At least it has GM styling (albeit the K2XX) A lot of the images floating around look like Bronco IIs or the current Bronco. Looking at the Broncos in my area (central Ontario, it seems to be a mix of 2 doors and 4 doors, 'mall rated' to ones that could go offroad.
I'm sure a AT4 and AT4X RPOs could be outfitted similar to a Rubicon if the braintrust understood the whole offroad scene. Crossing my fingers that if it does see the light that the front air dam/bumper doesn't extend below the center line of the tire...
Edited by revrnd
1 I created afterwardsGMCJimmyConcept.png.075805eff7a7b64dac442c6b1fd6db66.png
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 743 Guests (See full list)
